Everytime i need to power up some usb connected gadget in a controlled way with a power box i have issues finding cables that fits the purpose. And when i have finally found it, i need to cut it so it can connected to the power supply banana connector. When the job is done of course i throw away the cable. And nextt time i do it again and again! :( :)
Well that is how i came up with this project. A simple adaptor with one USB-C and one USB-A connector to make it backward compatible.
The first prototype was a bit to simple and dirty. I had only polarity protection and a couple of resistors on cc1 and cc2 pins to enable the USB-C Vbus voltage and the 2 connectors.
Yea that didn't quite work at all as intended!
During development and testing i realized that this could actually be o good gadget for lab purpose and that can make life easier for makers and engineers. So ai actually decided to try it as a crowdfunding campaign!!
KS-Elektronikdesign
INNER 1 Layer
INNER 2 Layer
CentyLab
MagicWolfi
