Refining the BLDC Fan Power Stage – Filtering and Protection Improvements
A project log for ESP32 SMD Rework Station with PID and Micropython
ESP32-based hot air SMD rework station with PID control, dual PCB design, built-in safety and calibration features.
srinivasan-m-sSrinivasan M S 03/29/2026 at 03:570 Comments
Following the observations from earlier testing, particularly the failure of the bulk capacitor across the BLDC fan supply, the power stage was revisited and refined to improve reliability and robustness.
The initial approach of placing a large capacitor directly across the fan terminals was found to be unsuitable due to the internal driver electronics of the BLDC fan. This prompted a more structured approach to filtering and protection.
Several modifications were implemented as part of this refinement:
🔧 1. Series Inductor in the 24V Supply Path
A power inductor (220 µH) was introduced in series with the 24V supply line feeding the fan.
This serves to:
By placing the inductor in series rather than across the load, the filtering action becomes more controlled and avoids stressing the fan’s internal electronics.
⚡ 2. Bulk Capacitor Relocated to Boost Converter Output
The bulk capacitor (470 µF), previously placed across the fan terminals, was moved to the output of the boost converter.
This ensures:
This placement aligns better with standard power supply design practices.
🛡️ 3. Addition of TVS Diode
A TVS diode was added across the boost converter output.
Purpose:
This is particularly useful in systems with inductive elements and switching loads.
🔄 4. Freewheeling Diode Across Fan Supply
A freewheeling diode was introduced across the BLDC fan supply.
Although BLDC fans include internal electronics, this diode provides:
⚙️ 5. Reduced Local Capacitance at Fan
A smaller capacitor (63 µF) was retained near the fan terminals.
This provides:
This value was found to be sufficient without interfering with the fan’s internal control circuitry.
🧠 Key Takeaways
This refinement highlights an important principle:
Understanding the interaction between power electronics and integrated loads is essential for reliable system design.
🔄 Outcome
After implementing these changes:
💬 Closing Note
This iterative refinement of the power stage significantly improved system robustness. It also reinforced the importance of adapting standard design practices based on the nature of the load.
Would be interested to hear how others approach filtering and protection for BLDC-based systems.
