3D Printer - T110 (2024)
Mini parts require a mini printer
0 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
A small attempt to use the Igus linear rails I had but got used on T115. The Z axis uses gobilda gotube (32mm OD) for strength and acts as the linear rods. Closed loop Nema 17 motors with corexy.
