SOES - Simple Open EtherCAT Slave on STM32F407
Software EtherCAT slave on STM32F407 + DP83848 PHY using SOES stack. No LAN9252 needed - full ESC emulated in
software.
0 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
Software EtherCAT Slave on STM32F407VET6 with DP83848 Ethernet PHY
This project implements a fully software-based EtherCAT slave using the SOES (Simple Open EtherCAT Slave) stack on an
STM32F407VET6 microcontroller. Unlike traditional implementations that require a dedicated EtherCAT Slave Controller
chip (such as LAN9252 or ET1100), this project emulates the entire ESC in software using the STM32's built-in Ethernet
MAC and a standard DP83848 PHY.
Key Features:
- Complete EtherCAT Slave Controller emulated in 8KB RAM
- FMMU-based logical-to-physical address translation for process data
- SII/EEPROM emulation in flash for device identification
- EtherCAT datagram processing: APRD/APWR, FPRD/FPWR, BRD/BWR, LRD/LWR/LRW
- CoE (CANopen over EtherCAT) with full Object Dictionary and SDO support
- TwinCAT compatible with included ESI/XML device description file
- 3x digital outputs (LEDs) and 3x digital inputs (buttons) as example I/O
- UART debug
