PCBs (12 of them!) arrived from dirtypcbs.com, they look great! A couple of issues to resolve...got the hole sizes wrong for the battery holder so needed to re-drill. Drilled through a tracing so had to add a jumper. But after that they work! Will update eagle files ASAP.
The main issue now is motor mounts. I am using the hot glue method at the moment. But if suitable wheels could be found (see for example ZaidPirwani's comment down below) then we could look at a clip or other method for mounting the motors parallel to the board.
