Reverse Engineering the Protocol
Using a logic analyzer, I captured I2C communication between a working Sony system and the wireless module.
Two key addresses control the system:
0x40 → Control & Status
- 0x13 → Status polling
- 0x50 → 17-byte data blocks
- 0x74 → Link trigger
0x41 → DSP Configuration
- Structured 5-byte sequences
- Likely digital filter coefficients
Sony continuously polls these registers, expecting realistic responses and correct timing.
The Breakthrough
After emulating the correct I2C behavior—especially interactions around register 0x74—the system:
- Accepts the emulated module
- Raises the LINK signal
- Transitions into an active state
This confirmed that pairing is enforced entirely through protocol behavior.
Timing Matters
Correct data alone is not enough.
- Slight timing mismatch → system rejects the module
- Accurate timing → successful pairing
Key signals involved:
- INT → Event notification (pulsed)
- LINK → Indicates successful pairing
- RESN → Reset signal from Sony
Audio Injection (I2S)
Once pairing succeeds, audio can be injected via I2S.
Expected signals:
- MCK ≈ 12.288 MHz
- LRCK = 48 kHz
- BCK ≈ 3.072 MHz
Important observation:
Without valid pairing, the system does not output I2S data at all.
Results
- LINK signal goes HIGH
- Front LED turns solid green
- Audio plays normally
The TA-SA100WR is fully functional again—without the original Sony transmitter.
What This Reveals
- The system is controlled entirely through I2C protocol
- DSP parameters are dynamically configured
- Audio is gated until pairing succeeds
- The hardware itself isn’t locked—the protocol is
Future Work
- Decode DSP data at address 0x41
- Replace sniffed data with a smarter emulator
- Explore multi-device pairing
Final Thought
Most proprietary systems aren’t truly locked—they’re just undocumented.
banoub banoub
Richard Aplin
markovchainsawmassacre
Bruce Land
Zac Zarev
