Reverse Engineering the Protocol
Using a logic analyzer, I captured I2C communication between a working Sony system and the wireless module.
Two key addresses control the system:
  • 0x40 → Control & Status
    • 0x13 → Status polling
    • 0x50 → 17-byte data blocks
    • 0x74 → Link trigger
  • 0x41 → DSP Configuration
    • Structured 5-byte sequences
    • Likely digital filter coefficients
Sony continuously polls these registers, expecting realistic responses and correct timing.
The Breakthrough
After emulating the correct I2C behavior—especially interactions around register 0x74—the system:
  • Accepts the emulated module
  • Raises the LINK signal
  • Transitions into an active state
This confirmed that pairing is enforced entirely through protocol behavior.
Timing Matters
Correct data alone is not enough.
  • Slight timing mismatch → system rejects the module
  • Accurate timing → successful pairing
Key signals involved:
  • INT → Event notification (pulsed)
  • LINK → Indicates successful pairing
  • RESN → Reset signal from Sony
Audio Injection (I2S)
Once pairing succeeds, audio can be injected via I2S.
Expected signals:
  • MCK ≈ 12.288 MHz
  • LRCK = 48 kHz
  • BCK ≈ 3.072 MHz
Important observation:
Without valid pairing, the system does not output I2S data at all.
Results
  • LINK signal goes HIGH
  • Front LED turns solid green
  • Audio plays normally
The TA-SA100WR is fully functional again—without the original Sony transmitter.
What This Reveals
  • The system is controlled entirely through I2C protocol
  • DSP parameters are dynamically configured
  • Audio is gated until pairing succeeds
  • The hardware itself isn’t locked—the protocol is
Future Work
  • Decode DSP data at address 0x41
  • Replace sniffed data with a smarter emulator
  • Explore multi-device pairing
Final Thought
Most proprietary systems aren’t truly locked—they’re just undocumented.
