The Mission
The nComputing L300 is a robust "Zero Client" terminal that has become a common sight in e-waste bins. But as an electronics engineer, I see more than a terminal; I see a high-quality development board powered by the ST SPEAr600 Dual-Core ARM926EJ-S processor. This project is a technical journey to liberate this hardware from its proprietary cage.
The Teardown & Discovery
This project documents the complete hardware analysis of the L300, including:
PCB Reverse Engineering: Identifying the UART headers, JTAG pads, and boot-mode pins.
Component Deep-Dive: Exploring the interaction between the SPEAr600 SoC, onboard DDR2 RAM, and SPI Flash.
Console Access: Brute-forcing the serial communication to intercept the bootloader.
Technical Repository: All findings, pinouts, and custom U-Boot/Kernel configurations are being updated in the official Ege Robotics GitHub repository.
