Teensy powered 405nm laser galvanometer scanner
A versatile lab tool for lithography, dyeing, detecting and more!
Starting from
has orders / reviews
Ships from
A 15x15x8cm Teensy powered 2-channels laser galvanometer projector designed for alternative photography development, plotter art, photoresist lithography, engraving, RGB stage laser performance, vibe coding without legacy protocols. Now it's on the way to get upgraded for 8 channels live control.
Overview
This project is a DIY laser scanner for alternative photography, photoresist exposure, PCB fabrication, engraving, and experimental 3D printing.
Instead of using the conventional ILDA workflow, it is built around audio-native control. The scanner is treated as a real-time signal system, making it easier to control from Max/MSP, DAWs, and custom code for generative paths, computational drawing, and direct live editing.
The current prototype uses a Teensy 4.0 + Teensy audio adaptor board for real-time 2 channels control. Next we need to go to 8 channels for more precise laser on/off control and RGB stage laser projectors.
Why audio-native control
Most galvo laser systems rely on ILDA, which is useful for compatibility but not ideal for rapid experimentation.
This project uses audio-native control because it allows:
  • real-time signal generation and modulation
  • direct control from Max/MSP, DAWs, DSP tools, and code
  • easier path editing without dealing with legacy protocols
  • live synthesis of laser motion instead of frame export
  • a better fit for hybrid uses across fabrication, imaging, and performance
In short, ILDA is good for interoperability, but audio-native control is better for an open and programmable workflow.
Sampling rate and resolution
The system runs as an audio-rate control architecture, with motion signals updated at standard audio sample rates such as 16-bit / 44.1 kHz
Practical resolution depends on the whole signal chain:
USB audio stream → Teensy audio engine → DAC / analog stage → galvo driver → optics
So performance is not defined by the microcontroller alone. It also depends on:
  • DAC bit depth
  • analog noise floor
  • galvo linearity
  • optical spot quality
  • calibration accuracy
Current development
  • Teensy 4.0 + Teensy audio adaptor board + customized amplifier board for stereo outputs (X/Y)
  • creative laser path generator, including TSP and stippling in python and max/msp format
  • USB real-time control (read as sound card in DAW)
  • standalone and lightweight machine design
  • audio-native workflows for direct software control
What is still missing
  • more than stereo DAC output
  • laser on/off is still controlled by DSP states rather than DAC channels
  • cleaner spot quality
  • autofocus or variable-focus optics for better spot control
What's next?
ADAU1452-CS42448-board
Applications (what are capable?)
  • alternative photography
  • cyanotype and other UV-sensitive coating experiments
  • photoresist lithography
  • PCB exposure and etching
  • SLA / resin 3D printing experiments
  • engraving and computational plotter-style drawing
Retro Mac interface simulation
Portable Network Graphics (PNG) - 1.40 MB - 04/07/2026 at 02:48
Preview
  • 1 × 15k galvanometer kit including galvanometer driver, 405nm laser diode, power, galvanometer holder
View project log
