Overview
This project is a DIY laser scanner for alternative photography, photoresist exposure, PCB fabrication, engraving, and experimental 3D printing.
Instead of using the conventional ILDA workflow, it is built around audio-native control. The scanner is treated as a real-time signal system, making it easier to control from Max/MSP, DAWs, and custom code for generative paths, computational drawing, and direct live editing.
The current prototype uses a Teensy 4.0 + Teensy audio adaptor board for real-time 2 channels control. Next we need to go to 8 channels for more precise laser on/off control and RGB stage laser projectors.
Why audio-native control
Most galvo laser systems rely on ILDA, which is useful for compatibility but not ideal for rapid experimentation.
This project uses audio-native control because it allows:
- real-time signal generation and modulation
- direct control from Max/MSP, DAWs, DSP tools, and code
- easier path editing without dealing with legacy protocols
- live synthesis of laser motion instead of frame export
- a better fit for hybrid uses across fabrication, imaging, and performance
In short, ILDA is good for interoperability, but audio-native control is better for an open and programmable workflow.
Sampling rate and resolution
The system runs as an audio-rate control architecture, with motion signals updated at standard audio sample rates such as 16-bit / 44.1 kHz
Practical resolution depends on the whole signal chain:
USB audio stream → Teensy audio engine → DAC / analog stage → galvo driver → optics
So performance is not defined by the microcontroller alone. It also depends on:
- DAC bit depth
- analog noise floor
- galvo linearity
- optical spot quality
- calibration accuracy
Current development
- Teensy 4.0 + Teensy audio adaptor board + customized amplifier board for stereo outputs (X/Y)
- creative laser path generator, including TSP and stippling in python and max/msp format
- USB real-time control (read as sound card in DAW)
- standalone and lightweight machine design
- audio-native workflows for direct software control
What is still missing
- more than stereo DAC output
- laser on/off is still controlled by DSP states rather than DAC channels
- cleaner spot quality
- autofocus or variable-focus optics for better spot control
What's next?
- Designing an amp board to connect to a ready made CS42448 board with TDM control for 8 channels of DC coupled +/- 5V outputs
- integrating g-code and ILDA with current audio native platform
Applications (what are capable?)
- alternative photography
- cyanotype and other UV-sensitive coating experiments
- photoresist lithography
- PCB exposure and etching
- SLA / resin 3D printing experiments
- engraving and computational plotter-style drawing
Shih Wei Chieh
Mattéo
Keith
roberts.trops
Tony Goacher
