Acheivement get! Build Middle Assembly
A project log for Mostly Printed CNC Build
This is a build log for the Vicious Circle MPCNC machine
kendoken.do • 04/09/2017 at 03:13•0 Comments
Ok. The minecraft references are getting a bit stretched.
So I built the middle assembly. I should read the instructions before I start building...
It went fairly smooth. I ran into some tight spots tightening nuts, but thats what needle nose pliers are for. Mostly these incidents were me getting ahead of instructions...
I know it looks kinda complicated, but the truth is... it is a bit complicated. That said, following the instructions actually helped!
