Karosa ŠM11 test
A project log for Magnetic Road Transport System for TT Scale Layout
Magnetic Road Transport System for TT Scale Layout — DIY Control on ESP32
oldaOlda 04/07/2026 at 15:540 Comments
First test drive — bus on magnetic track
Test drive of a bus on the magnetic track in the quarry test polygon. The purpose was to verify curve clearance with an extended chassis. This is the first long chassis on this track, so the key question was whether it would fit through the switchbacks at all. Manual control.
The bus has an issue with the front axle lifting the chassis in curves — currently unsolved due to the constraints of TT scale, but it´s in progress :)
Next step — automatic position tracking system. In traditional DCC, you only know that a train is somewhere within a block, not where exactly. This system aims to track vehicle position continuously along the entire route with reasonable accuracy, using hall sensor pairs as reference points and speed-based interpolation between them.
