Externally powering a Casio F-91W
A project log for Gravity-Powered Digital Clock
My watch runs off "disposable" lithium cells. I retrofit it to run like a grandfather clock: weights and gravity.
ethanEthan 04/18/2026 at 02:270 Comments
  1. Open watch by unscrewing back panel
  2. Pull electronics assembly out
  3. Unclip the battery cover (stamped steel) from the screen chassis (white plastic) by lifting the 4 clips around the perimeter
  4. Remove the battery (might be taped onto PCB)
  5. Pull apart the PCB and screen chassis (white plastic)
  6. Remove the negative battery terminal contact spring from the PCB (just pull it off)
  7. Solder thin flexible wires to the terminals as shown
  8. Cover negative solder joint with tape to prevent short
  9. Reattach screen chassis to PCB (line up the alignment pegs and press gently together)
  10. Clip the battery cover back on, making sure you don't press too hard on the bare LCD
  11. I partially reassembled the watch, partially to protect everything, but mostly to make sure I don't lose any more parts. The back cover screws are very long, so if you just partially tighten them the wires stay comfortable.
