Mechanical log, past week
A project log for Gravity-Powered Digital Clock
My watch runs off "disposable" lithium cells. I retrofit it to run like a grandfather clock: weights and gravity.
ethanEthan 04/20/2026 at 00:060 Comments
Update on the last ~week of mechanics work.
I'm using Onshape to design the mechanical setup.
I'm using a spur gear generator feature; I can't figure out how to link to it here but of the couple I've tried this is my favorite.
All parts shown in Onshape are 3d-printed with plain PLA. Structure is M3 threaded standoffs. Everything is set up to fit on the bed of my Bambu lab A1 mini.
Stages are a series of double-reduction idler gears:
axleinputoutputratioaxlebearingratio, tot.
1spool for rope60T gear, m=1mm11/8" brass rodplain1
212T m=1mm60T, m=0.75mm51/8" brass rodplain5
312T m=0.7560T m=0.7553/64" brassplain25
412T m=0.7560T m=0.7553/64" brassplain125
512T m=0.7560T m=0.7551mm SSBall625
612T m=0.7560T m=0.7551mm SSBall3125
712T m=0.7560T m=0.7551mm SSBall15625
812T m=0.75magnet disc51mm SSBall78125
Input torque is determined by charge mass and spool diameter.
The first few stages of the gear train use plain bearings -- simple brass rods from the art supply store as axles, through a bore hole in 3d-printed PLA. I'm using 1/8" and 3/64" rods for the first 2 and second 2 bearings, respectively. In these first few stages friction isn't really a concern because input torque is high.
The next 4 axles use tiny ball bearings I found on amazon. I bought them to fit into my existing design to retrofit plain bearings without really grokking how tiny these are; by far the smallest ball bearings I've ever seen. 3mm OD, 1mmID, 1mm thick. They reduce friction by a lot; hard to quantify without better testing I don't have time for, but a flicked gear spins about 4x longer than in a plain bearing. Friction becomes exponentially relevant at later stages.
Since the ball bearing ID is smaller than 3/64", I use 1mm stainless steel wire as the axles here. I pull a bit off the wire spool, chuck one end in a drill, and spin it while pulling on the wire with needle-nose pliers. This straightens it, thins the wire a little, and tapers one end for easier assembly.
Gears are spaced on axles using bushings made from 1mm heat-shrink tubing. Clearance is really important.
