Motor Repair
A project log for Mechanical Television - only parts from 1920s
Building a mechanical television with parts only from the 1920s. Focusing on simplicity.
paul-kocylaPaul Kocyla 04/18/2026 at 17:120 Comments
I got two synchronous motors (see previous log).
The most period correct model is seized.
The bearings look OK, but the grease inside has hardened.
I used flux remover to get them going almost instantly. Now I am rinsing the rotor in isopropyl alcohol.
The inside looks undamaged - i will just wipe it clean from eventual rust particles and will not give it any other treatment.
The windings measure good.
