Need some input on what kind of controller I should use.
It will either be an arduino (because most people already have one) or the Raspberry Pi.
Servo driver will use the chip from the Adafruit 16-channel servo driver (i2c control).
I'm leaning towards the RPi just so that we can run some basic OpenCV code on it to set part localization (PickNPlace) usage).
Thoughts?
