Quick Start
python depth_map.py MAP00.csv python interpolated_map.py MAP00.csv python contour_map.py MAP00.csv python csv_to_kml_colored.py MAP00.csv python google_earth_overlay.py MAP00.csv
Oceanic Measurement & Environmental Geospatial Array
A compact underwater survey system that collects depth, position, and environmental data from a moving ROV and converts those measurements into bathymetric maps and georeferenced outputs. Measurements are filtered in real time using quality and spatial constraints, producing both a complete log and a reduced mapping dataset. A continuous surface is generated from the filtered points through spatial interpolation.
Overview
The system is built around an Arduino-based capture device and a Python-based processing workflow.
It is designed to:
- record reliable field data in real time
- filter out low-quality measurements
- generate usable spatial maps from irregular samples
- visualize results as raster maps and georeferenced overlays
Repository Structure
arduino/ rov_logger_mapping.ino docs/ SYSTEM.md SCRIPTS.md scripts/ csv_to_kml.py csv_to_kml_colored.py depth_map.py interpolated_map.py contour_map.py google_earth_overlay.py example_data/ MAP00.CSV
System Architecture
Architecture Overview
| Layer | Function |
| Capture (Arduino) | GPS (position + UTC), sonar depth, temperature, IMU orientation, SD logging |
| Processing (Python) | CSV parsing, filtering, interpolation (IDW), contour generation |
| Output | Depth maps, contour maps, KML files, Google Earth overlays |
Hardware
Components
- Arduino Mega
- GPS module (UART)
- Waterproof ultrasonic distance sensor
- DS18B20 temperature sensor
- BNO085 IMU
- I2C 16×2 LCD
- SD card module
Wiring Summary
| Component | Connection |
| GPS | RX1 (19), TX1 (18) |
| Ultrasonic | RX2 (17), TX2 (16) |
| SD Card | CS pin 53 |
| Temperature Sensor | Pin 6 |
| LCD / IMU | SDA (20), SCL (21) |
Data Pipeline
1. Data Capture
The Arduino logger writes two files:
dataXX.csv— complete system log (diagnostics)mapXX.csv— filtered survey dataset
Mapping points are recorded only when the system detects:
- valid GPS fix
- acceptable HDOP
- sufficient satellite count
- recent fix age
- valid depth reading
- stable orientation (pitch/roll)
- acceptable platform speed
- minimum spacing from the previous point
2. Processing
Run scripts on the mapping dataset:
python depth_map.py MAP00.CSV python interpolated_map.py MAP00.CSV python contour_map.py MAP00.CSV python google_earth_overlay.py MAP00.CSV
3. Outputs
- Scatter map — validation of raw coverage
- Interpolated map — continuous surface model
- Contour map — readable bathymetry
- KML + overlay — georeferenced visualization
Key Features
UTC Time Logging
All timestamps are recorded in UTC to eliminate timezone ambiguity.
Depth Smoothing
A moving average filter reduces sonar noise and rejects transient spikes.
Sound Speed Correction
Depth is adjusted using a temperature-based estimate of sound speed.
Real-Time Data Filtering
Measurements are evaluated during acquisition to ensure mapping data meets defined quality thresholds.
Spatial Interpolation
Inverse Distance Weighting (IDW) converts discrete samples into continuous surfaces.
Data Format
Mapping File (mapXX.csv)
point,date_utc,time_utc,lat,lng,depth_cm,temp_c,satellites,hdop,speed_kmph,fix_age_ms,pitch_deg,roll_deg,imu_acc
Outputs at a Glance
dataXX.csv— complete acquisition logmapXX.csv— filtered survey dataset*_depth_map.png— raw point coverage*_interpolated.png— interpolated surface*_contours.png— contour visualization*_colored.kml— colorized Google Earth points*_overlay.kmz— Google Earth ground overlay
Example Workflow
python depth_map.py example_data/MAP00.CSV python interpolated_map.py example_data/MAP00.CSV python contour_map.py example_data/MAP00.CSV python csv_to_kml_colored.py example_data/MAP00.CSV python google_earth_overlay.py example_data/MAP00.CSV
Example Output
Running the scripts produces:
*_depth_map.png*_interpolated.png*_contours.png*_colored.kml*_overlay.kmz
Method
This project implements a self-contained bathymetric survey system using a mobile ROV platform.
As the device moves, it continuously samples depth, position, and environmental data. Each measurement is evaluated in real time against defined quality constraints, including GPS validity, HDOP, satellite count, fix age, platform orientation, and spatial separation.
The system produces two datasets:
- a complete log (
dataXX.csv) containing all measurements - a filtered mapping dataset (
mapXX.csv) containing only survey-quality points
The mapping dataset is generated by enforcing minimum spacing between points and rejecting measurements that do not meet stability or accuracy thresholds.
A continuous surface is constructed from the filtered dataset using spatial interpolation (Inverse Distance Weighting). The resulting map is a derived model, determined by sampling density, platform motion, and filtering criteria rather than direct sensor output.
This architecture separates acquisition, validation, and surface reconstruction into distinct stages, allowing control over data quality during both capture and processing.
Limitations
- Ultrasonic sensors have beam spread and limited range underwater
- GPS accuracy limits spatial resolution
- Sound speed correction uses temperature only
- Interpolation produces a modeled surface, not direct observation
- Map quality depends on survey spacing, speed, and stability
Future Improvements
- pressure-based depth sensor integration
- salinity-aware sound speed correction
- real-time mapping preview
- automated survey path planning
- higher-resolution interpolation methods
- contour labeling and hillshading
- live telemetry and visualization
Testing
A sample file is included:
Run:
Documentation
Scripts Overview:
These scripts work with CSV files produced by the Arduino ROV mapping logger.
Supported CSV patterns:
- comment/version lines beginning with
# lat+lonorlat+lngdepth_mordepth_cm- optional
utc
Included scripts
1. csv_to_kml.py
Creates a simple point KML for Google Earth.
python csv_to_kml.py MAP00.CSV
2. csv_to_kml_colored.py
Creates a colored point KML where depth controls point color.
python csv_to_kml_colored.py MAP00.CSV
3. depth_map.py
Creates a scatter map PNG from the CSV.
4. interpolated_map.py
Creates a smoother interpolated bathymetric image using inverse distance weighting.
5. contour_map.py
Creates a filled contour bathymetric image with contour lines and sample-point overlay.
6. google_earth_overlay.py
Creates:
- a georeferenced overlay KMZ
- a KML GroundOverlay that places the image correctly in Google Earth
Common options
Many scripts support:
--output--grid-size--power
Examples:
python interpolated_map.py MAP00.CSV --grid-size 300 --power 2.0 python contour_map.py MAP00.CSV --grid-size 300 --levels 12 python google_earth_overlay.py MAP00.CSV --grid-size 300
Outputs
By default, files are written next to the input CSV using derived names:
MAP00.kmlMAP00_colored.kmlMAP00_depth_map.pngMAP00_interpolated.pngMAP00_contours.pngMAP00_overlay.pngMAP00_overlay.kml
Notes
- Depth is treated as positive downward
- Scripts ignore comment lines beginning with
# - For best results, use the filtered
MAPxx.CSV, not the rawDATAxx.CSV
Jonathan Capone
