The LumiBand app - BLE control, animations, and the joy of app store approvals
A project log for LumiBand Gen3 - Wireless DMX LED wristband ESP32
A wearable LED fixture that receives wireless DMX512 over WiFi. Because why should the lighting rig stop at the stage edge.
markus-loefflerMarkus Loeffler 05/13/2026 at 18:100 Comments
Every hardware project eventually needs an app. LumiBand is no exception, the Gen3 uses BLE for setup and control, which means someone has to write the software side. That someone was me.
What the app does The LumiBand app is built in Flutter, which was the right call for a solo developer needing iOS and Android from a single codebase. It handles four main functions:
App Store status iOS version is live on the App Store now, Apple's review process was straightforward for a BLE hardware companion app. They came back with an ask to record the app pairing with the actual wristband.
Android is a different story. Google Play requires a mandatory closed testing period of at least 14 days with a minimum of 12 active testers before granting production access. The app itself passed review - it's purely a process gate. Currently recruiting Android testers to complete the requirement.
If you have an Android device and want early access to the LumiBand app, drop a comment below :: looking for testers right now.
Screenshots in the gallery above show the device pairing flow, basic modes, playlist, and animation editor.
