Elecaenta 25W: Solar Panel Upgrade
Great cells, not so great circuitry...
Recently, i bought a 25W solar panel for bikepacking adventures. It is made by Elecaenta, and advertises a total of 4A, 5A USB output (already, we seem to have dropped 5 Watts from the product's own name - but alright, let's say that is due to efficiency...)
When testing it, it performed really well on cloudy days. 5-7W while fully overcast? That's great, and shows the cells themselves are quite good.
But when the first sunny days came along, time had come for some more serious testing.
I hooked up my power bank and my phone - they are easily capable of exceeding 4A in total.
But: At only 15W, the panel began to switch of repeatedly, only to turn on again a few seconds later...
So, this is how this project began.
So: First, let's have a look inside. The PCB shows a chip that was marked as "SunPlus" - no chance to find any matching datasheet.
So, i let some AI tools suggest what could be inside this chip - probably it was rebranded, therefore i had to find promising candidates, and compare their actual pinouts.
I found that the MP2303 buck converter would match the layout quite well, and the inductor suggested in the datasheet has the exact same value of the one built into the panel.
Well, the MP2303 goes up to 3A only - and when close to that, it is probably also going to overheat soon, as it has 125mOhm switch resistance. At 3A, this already amounts to a Watt - an awful lot for a small SOIC package.
And judging by that, there was no way i could use this exact IC in order to deliver the 4A promised to me. Searching for pin-compatible replacements also left me without results.
So, i did what sounds like a real promising idea: I searched the web for cheap 5A buck converters. I set my mind on just throwing them in there, in hope that this would work. I got some Mini560 boards for a few bucks. To be continued...
  • MINI560: First tests
    t.oster9204/18/2026 at 12:06 0 comments
    When the Mini560 boards arrived, i desoldered the voltage converter from the original PCB.
    I sawed out a piece of the pcb, so that the Mini560 board could fit.
    Now, the converter could deliver 4A - great, i got more than 20 Watts out of it!
    But it seemed to be finicky. The mini560 boards are just buck converters, and they don't have any MPPT - maximum power point tracking. This is a feature needed to get the most power out of solar cells.
    So, i decided that i would build a poor man's version of an MPPT control - just using the Mini560 board.
View project log
