Network-Dashboard is a lightweight, cross-platform Network Operations Center (NOC) and environmental dashboard built with Python 3 and PySide6 (Qt). Designed for home labs, makers, and network enthusiasts, it transforms standard raw network diagnostics into a clean, real-time visual hub.
Beyond its core multi-threaded discovery engine, the dashboard integrates automated environmental tracking and persistent configuration state—making it ideal as a dedicated "always-on" monitoring panel for secondary displays or Raspberry Pi touchscreens.
Key Features
1. Multi-Threaded Network Discovery
- Active Mapping: Utilizes Scapy-driven ARP pinging to dynamically discover and map all active IPv4 hosts on the local subnet.
- Concurrent Scanning: Leverages Python threading to ensure the user interface remains completely fluid and responsive, even during heavy network discovery cycles.
2. Device Management & Persistent Logging
- SQLite Data Layer: Logs first-seen and last-seen timestamps for every device discovered on the network.
- Custom Nicknames: Allows users to assign friendly, permanent aliases to MAC addresses directly from the UI, replacing obscure vendor names with readable labels.
- MAC Vendor Resolution: Automatically queries and maps OUI prefixes locally to identify device manufacturers out of the box.
3. Integrated Environmental Context
- Zero-Key Weather Monitoring: Automatically resolves your local weather conditions and a 5-day forecast on boot using multi-provider public IP geolocation—no proprietary API keys or manual location tagging required. Auto updates every 30 minutes.
- Dynamic Location Overrides: Allows users to manually force specific location and units. these are saved in the config.ini file so setings for the weather are remembered
- dynamic background based on current weather. autochanges if the weather forecast changes.
4. Smart UI & State Persistence
- Config Preservation (
config.ini): Seamlessly remembers your preferred window geometry, custom location configurations, and UI states across reboots. - Adaptive Scaling: Features a flexible, responsive layout that shifts elegantly from a default compact view to expansive full-screen monitoring setups.
Possible smart automation add on :-
Future-Proof / Extensible Architecture: While designed strictly as a local network visualizer and ambient weather panel, the clean, grid-based PySide6 UI layout can easily be adapted as a central dashboard for Home Assistant, MQTT listeners, or custom smart home automation hubs. You are very welcome to download and adapt for your smart home.
Technical Specifications
- Language: Python 3.x
- GUI Framework: PySide6 (Qt for Python)
- Network Capabilities: Scapy, Socket,
psutil - Data & Configuration: SQLite3 (Device History),
ConfigParser(UI & System State) - External Services: Open-Meteo API, Public IP Geolocation APIs
- OS Compatibility: Linux (requires
sudofor raw ARP sockets), macOS, Windows
diddy
7h30th3r0n3
Ai-Thinker
platis.solutions
Wei Wang
