Introduction
The LiPo Power Board functions as a power controller for devices powered by batteries, mainly aimed at prototyping use due to its breakout-style design. It operates with a single 3.7V LiPo cell and delivers two voltage outputs: a stable 3.3V and another adjustable output that can supply higher voltage and current levels. A built-in switch enables users to turn off power to both outputs when needed. The board supports battery charging through USB-C and DC jack connectors.
One of its key advantages is the flexible boost converter section, where the output voltage can be easily modified by adjusting the ratio of two resistors. This design also allows duplication of the boost circuit to create additional voltage outputs if required.
This board is particularly useful in applications where a microcontroller operates at 3.3V while other components, such as sensors or devices like WS2812B LEDs, require a higher and more stable voltage supply.
For Full Project: https://electronicsworkshops.com/power-management-board-for-battery-powered-projects/
Features
Low leakage current design for improved battery efficiency
3.81mm pin spacing for easy integration and compatibility
Includes 3D model support for accurate design and enclosure planning
Minimum guaranteed output current at 5V: over 400mA (tested at 3.3V input)
1. Input Power Section (USB & DC Connector)
2. On-Off Control Circuit
3. Battery Charging Circuit
4. Battery Connector
5. 3.3V Regulator Section
6. 5V Boost Converter Section
7. Load Switch / Power Gating
8. Output Header
Provides multiple accessible signals:
Pcb Files
3D files
Order Directly from PCB WAY
I have already uploaded all these required manufacturing files in PCBWAY website. You can easily go to the below link and place you order, and get your Own  Home Automation PCB manufactured from one of the best pcb manufacturer PCBWAY
Order Now …………..
Conclusion
The LiPo Power Board presents a well-integrated and flexible solution for managing power in battery-operated electronic systems. By combining efficient LiPo charging, stable 3.3V regulation, and an adjustable boost converter for higher voltage needs, it supports a wide range of components within a single compact design. Additional features such as input protection, power control switching, and configurable charging parameters enhance its reliability and adaptability. Despite minor limitations like boost converter leakage, the overall design makes it highly suitable for prototyping and embedded applications requiring multiple voltage levels from a single LiPo battery.
For Full Project:
