1st May 2026 - Project plan (and some post through my letterbox)
A project log for Polyphonic Analog Synthesiser
Building a modern interpretation of a polyphonic modular analog synthesizer at the transistor level, inspired by early 1970s-80s designs.
charlie-theobaldCharlie Theobald 05/02/2026 at 19:430 Comments
As predicted, none of the exams I've had this week went particularly well. But maybe I'll surprise myself like last year when results come out.
This week
Not much progress this week due to exams. As mentioned in last week's update, I hope to start building from around mid-May.
When I haven't been in Laplace transform jail, this week I've been thinking about project timelines and also about possible designs for my VCO. I'll start with discussing project timelines first.
Project stageThings to doDeadline
VCO and oscillator coreDecide on oscillator type, design wave generator circuits, prototype on breadboards, design PCBs, test initial prototype31st May
MIDI control integrationLinking the VCO to a MIDI source, implement polyphony14th June
Design of envelope generator, VCA and VCFDecide on VCA/VCF types, decide between analog / digital implementations, prototype on breadboards, design PCBs, test initial prototype11th July
Buffer period for integration testing / parts delayCombining VCO, VCA and VCF designs to work effectively together, analysis of noise performance, hopefully prototype design PCBs have arrived31st July
Improving stabilityAdding improved power supply and temperature compensation for more advanced features latermid Aug
"Nice-to-haves"Noise generator, LFO, sample and hold, frequency modulated / sync VCOsSep
If I can get to having a good VCO, VCF and VCA by the end of July, I'll be happy, as this will give me a solid two months to add interesting improvements. I have an assessed university project from May-June, and an internship during July, both of which should come first, so I've given extra time to some of the earlier deadlines.
This plan almost definitely will change during the course of the project. This is my first build at this scale, and my first time making a synthesizer, so I'm prepared to anticipate and embrace delays.
In the post
CV-12 ORAC chip from Midimuso (£17.49 as part of a kit containing a PCB and other components)
The CV-12 is a remarkable chip, which is capable of converting digital MIDI signals into a CV (control voltage) and a trigger (a short pulse that tells an envelope generator / amplifier when a MIDI Note On event is detected).
Many MIDI to CV/Trig converters are very expensive, with good ones costing around £100 each. These are intended more for the Eurorack market rather than for ground-up electronics builds, so don't really fit my requirements or budget.
What makes the CV-12 special is that it is capable of polyphonic MIDI to CV conversion, meaning it is capable of outputting many control voltages (corresponding to many different notes) at once. This means it becomes possible to play chords from the get-go. It's also fully configurable with various mode changes. Polyphony can be sacrificed for additional MIDI parameters like note pressure and pitch bend, and even VCF parameters like cutoff / resonance. Considering what this thing can do, £17 is an absolute bargain.
SMD soldering practice kit, £0.75 from AliExpress
I also bought an SMD soldering practice kit, if not for learning how to solder SMD components for this project then just for a bit of fun. This consists of a small, and a variety of SMD resistors, capacitors and chips in different sizes to practice with.
I don't think I quite realised just how small SMD components really are - whilst the 1206 and 0805 size look manageable to solder with my iron, the smallest 0402 size ones are absolutely tiny.
