SPI flash to Micro Sd adapter
Simple SPI flash adapter / breakout in Micro SD shape
Why?
- I have embeded design with micro sd slot and I want play with SPI FLASH
- I want test more types memories
- I want try Osh park 0.8mm boards service
- I want small golden board in to micro sd slot :-)
- board have header and is usable in breadboards.
variants:
- top memory
- bottom memory
- and best DIL8 > you can program flash memory in USB programmer and then use in your board
Is only for embeded boards, spi flash interface is not compatible with micro sd protocol !
morgan wrote 05/24/2019 at 22:22 point
I'd love to order this for an experiment, mind enabling sharing on OSH Park?
Antti Lukats wrote 05/08/2017 at 06:46 point
I did this like PCB some 10 years ago ;)
josephchrzempiec wrote 04/04/2017 at 20:58 point
Hello i was wondering something. What could you do with this type of project? I'm not much of a programmer but hardware is something i do know and i know currently at this moment that you can not interface a attiny85 chip to a PC without a programmer. I know a FTDI or a CH340 programmer is needed but i never heard of a Micro SD Flash to USB ever used?  I know the Micro Sd card IS SPI But that is all.
