The OpenPLC Editor features a simple and user-friendly interface, making it highly suitable for beginners and those eager to learn about the world of industrial automation without unnecessary complexity. It is part of the open-source OpenPLC platform, which stands as one of the first free solutions that simulates the operation of a real PLC in accordance with the global industrial standard, IEC 61131-3.
What further distinguishes this software is its support for a wide range of controllers and platforms. It can be deployed on devices such as Arduino, ESP32, ESP8266, and Raspberry Pi, or even run on a computer as a Soft PLC. This versatility grants users significant freedom in choosing the appropriate hardware and makes the transition from learning to practical application easy, without the need for expensive industrial equipment.
From a programming perspective, the OpenPLC Editor supports all recognized industrial languages, such as Ladder Diagram (LD), Function Block Diagram (FBD), Structured Text (ST), and Sequential Function Chart (SFC)—the same languages used in professional systems. This means you are learning with the exact tools and logic applied in real-world factories.
Regarding advanced features, the software provides real-time monitoring and debugging (Live Debug). You can connect it to your hardware (such as a Raspberry Pi) and watch the values and logic change while the program is running, which greatly assists in understanding code execution and troubleshooting. Additionally, the system includes a runtime environment equipped with a web server, allowing you to upload programs, control them, and monitor I/O remotely via a web browser.
Overall, the OpenPLC Editor can be considered a powerful tool that bridges the gap between simplicity and professionalism. It enables you to transform simple microcontrollers into functional PLCs and build projects in industrial automation, the Internet of Things (IoT), and SCADA systems—all at a low cost and within a learning environment that is very close to industrial reality.
Salah_Eddine
CFA
Esmacat
CanHobby.ca
Adam Feuer
