Putting an RTL-SDR inside the case of an RPi CM5IO
PCIe-to-USB adapter to add an internal USB port to the CM5IO
0 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
I want to run some RTL-SDR software on a Raspberry Pi CM5 on the CM5IO board + case, but I don't want the RTL-SDR to be dangling out the front.
To tidy things up, I made a PCIe to USB adapter to add an internal USB port, which lets me place the RTL-SDR inside the case. The SMA port on the RTL-SDR sticks out of the case through the hole meant for the WiFi/Bluetooth antenna.
