Custom firmware for CRM3007L
Building custom firmware for CRM3007L espresso appliance factory board using SDCC.
vasVas
0 followers
CRM3007L espresso appliance factory board uses OnBright OB38R16T1 microcontroller. It's a 8052 compatible MCU, so SDCC is a good choice for the compiler.
  • First working prototype
    Vasan hour ago 0 comments
    This project is published when there's plenty is done already so let's describe what's already working.
    • OnBright MCU specific HAL is extracted and adapted for SDCC
    • The code compiles and runs on the actual MCU
    What's next:
    • Make OTA library for ESP32 to be able to flash OnBright MCU without proprietary flasher
    • Make WDT work with ADC (right now ADC fails when WDT is enabled)
View project log
  • 1
    MCU flashing
    Use SynMOS MSM9066 dongle and SMAP tool
View all instructions
