Version 2
A project log for Rocket Payload
Electronic Payload to record and display flight data for model rocket.
bud-bennettBud Bennett • 06/06/2026 at 21:14•0 Comments
v2.0 Prototypes:
I sent Claude to canvas the available collection of hobbyist model rocket flight recorders and make recommendations for upgraded features. He came back with two suggestions:
  1. Integrate the USB interface with a controller that doesn't require Windoze to install a special driver. This would spare the user additional expense of purchasing the CP2102 adapter and the custom wire harness. A simple USB type-C terminated cable is all that is required to connect and download flight data.
  2. Add a (PRO) version that will allow the user to record multiple flights without having to connect a USB port for downloading data.
  3. Increase the baud rate of the USB connection from 9600 to 76800. This will reduce the time required to download multiple flight data.
With these upgrades the Payload would be competitive with all of the sub-$125 offerings: Many don't include an accelerometer. None of them offer an exhaustive multi-OS interface -- usually one or two at most -- and some don't offer downloading data. Many require the user to purchase an external battery charging module at additional cost. As far as I can tell, the only feature this Payload lacks is a Bluetooth connection primarily for interfacing to an iPhone.
v2 changes from v1:
All of this was incorporated into the same dimension PCB:
