Finally an update on the "public webpage"
After a long time, working on a separate branch I've finally decided that it is time for a merge.
Of course this is full of old and new bugs, looks a bit ugly, but some new features are also there.
New stuff:
- Horizontal pin arrays: While still buggy, it now supports horizontally aligned pin arrays, and the labels can be on upper or lower side.
- Refactored the JSON files containing core and module info: This is not visible, but accessing core and core packaging information can be made visible on the webpage someday using the current data file structure.
- Editor Mode: For now just existing modules can be edited, in a limited way. Open a module in normal mode, then click "Editor Mode" and it can be changed.
Features still on their way:
- MCU editing: During module editor testing I still had to edit the core JSON files manually. Painful thing to do, it will have its own editor.
- New core/module: For now creating new stuff needs heavy manual file editing.
- Edit peripherals: Add peripheral editing to both MCU and module.
- And lots more, primarily for the normal usage: Peripherals need to be checked for collisions, invalid pin usage. Show visually on the module image the input/output/pwm. Include also image from backside, and have a "flip" button. Maybe include quick link to datasheets and board schematics.
And many more I forgot to mention here, plus heavy bugfixing.
For now, vacation awaits! :)
