It has been a long "vacation" break. Well, if some can call a full-time job like that. :)
At the point of the merge of the editor branch, I've decided to call it "alpha v0.1". Sooo.. what's up next?
Alpha v0.2 goals:
- Core editor features and cleanup: add new core, add/remove packages, edit peripherals, save/load the core.
- Module editor features and cleanup: add/remove/modify front and back images, edit peripherals, save/load module.
This doesn't sound much, but with these the main tool will be more usable.
With this "tool inside the tool" it will be much more easy to add content. And with content, this concept can become really usable.
I will try to make it as easy as possible for everyone to contribute through the editors.
