WHAT THIS IS
A home power generation, storage, and community grid-feed system
built around a triple-motor permanent magnet outrunner and a
cog-relief permanent magnet generator. No combustion. No fuel.
No external excitation required. All mechanical details declared
public domain.
THE DRIVE STAGE — TRIPLE-MOTOR OUTRUNNER
One outrunner shell. Three motors inside it — M1, M2, M3 —
separated by 120 degrees each. The axle runs all the way through
the assembly, anchored at both ends to fixed frame posts.
Three motors at 3 cog positions each = 9-position total cog cycle.
At no point in the rotation are all three motors at dead center
simultaneously. The shell always has at least one motor in push
or pull drive. Dead center is never shared.
The three staggered drive pulses per cog cycle deliver a far
smoother torque stream to the flywheel t
