The Parts.
A project log for Enviclo
Advanced Open Source MicroEnvironmental Control System
daniyal-ansariDaniyal Ansari • 07/06/2017 at 19:41•0 Comments
1 5 X Soil Hygrometer Humidity Detection Module Moisture Water Sensor for Arduino $8.89
1 Adafruit (PID 393) AM2302 (wired DHT22) temperature-humidity sensor $16.00
1 JBtek 8 Channel DC 5V Relay Module for Arduino Raspberry Pi DSP AVR PIC ARM $8.98
2 2PCS Two Position Three Way Miniature Solenoid Valve DC 5V 6V $9.95
1 LEDMO Switching Converter, AC/DC Power Supply, AC 100V/240V to DC 12V 10A $9.95
1 Yeeco DC 3.5-12V 6V 9V 12V Water Pump Electric Brushless $13.46
1 Elegoo MEGA 2560 R3 Board ATmega2560 ATMEGA16U2 $11.99
1 OCR 20PCS 2.54mm Breakaway PCB Board 40Pin Male and Female Header $6.49
1 Lasko 106 My Heat Personal Ceramic Heater, Purple $19.23
1 URBEST Inlet Module Plug 5A Fuse Switch Male Power Socket 10A 250V 3 Pin $5.99
1 Sandisk Ultra - Flash memory card - 16 GB $9.95
1 Arducam 15 Pin 1.0mm Pitch to 22 Pin 0.5mm Camera Cable for Raspberry Pi Zero $7.99
1 Remington Industries 22 AWG Gauge Stranded Hook-Up Wire $10.35
1 Heat Shrink Tubing 532pcs innhom Ratio 2:1 $7.49
1 Mini Mist Maker Fogger Water Fountain Pond Fog Machine Atomizer $10.99
1 JSER Left Angled 90 Degree Micro USB OTG to Standard B Type $6.00
1 18 in. x 24 in. x 0.093 in. Clear Acrylic Sheet Glass Replacement $10.27
1 GE All Purpose Silicone I 10.1 oz. Clear Window and Door Caulk $5.21
1 Abbott Rubber Company 1 in. O.D. x 3/4 in. I.D. x 10 ft. Vinyl Tube $21.32
1 Unique Bargains 13.1Ft Clear White Flexible Air Pump Bubble Oxygen Pipe Tube $9.38
1 Aqueon® Glass Aquarium 10gal $14.99
1 Arducam 1602 16x2 LCD Display Module White on Blue with Backlight $5.99
1 10Pcs 5 x 7 cm DIY Prototype Paper PCB Universal Board New $6.99
1 PryEU 4-Pack White 12V Super Bright LED Strip Lights Waterproof 12'' 30cm $12.48
1 RoadPro RPCBH-25 Hardwire Replacement CB Power Cord-2 wire , 25-Feet $5.23
1 ClearMax Universal 18AWG Power Cord (UL Approved), 12-Feet $7.99
1 50CT Peat Strip $6.00
1 Aqua Culture Small Pebbles Aquarium Gravel, 5 lb $3.98
1 Small Enclosed Piezo w/Wires $4.94
1 Pixma USB 2.0 Printer Cable Cord A-B 10' 10 FT $4.99
3 USB Car Charger $0.75
1 Cooler Master Sleeve Bearing 92mm Silent Fan $5.97
2 Cooler Master Rifle Bearing 80mm Silent Cooling Fan $4.99
1 TOOGOO(R) 30mm x 30mm x 10mm 3010S 12V 0.06A Brushless DC Cooling Fan $2.17
1 1 Gallon Plastic Jar, Wide Mouth, Clear $10.69
1 Crystal Clear Plastic Jars with Screw on Lids 16 oz Set 6 Wide Mouth $16.95
1 Blue Sea Systems 8 Circuit 20A Terminal Block $5.24
1 PCB Mount Screw Terminal Block Connector, 100 Pack (2 Pole 5 mm Pitch, 10A 300V) $9.95
1 Hisurprise 1000 Pcs Black Plastic Cable Zip Tie Fasten Wrap 80mm x 2mm $3.40
1 6 Gauge Clear Vinyl Fabric By The Yard $1.95
1 Sonline 50x Through Hole Carbon Film Resistors 220 Ohm 1/4W 5% $1.78
Total (Your price tag may vary based on what you buy.) $280.07
Notes:
