| 1 | 5 X Soil Hygrometer Humidity Detection Module Moisture Water Sensor for Arduino | $8.89 |
| 1 | Adafruit (PID 393) AM2302 (wired DHT22) temperature-humidity sensor | $16.00 |
| 1 | JBtek 8 Channel DC 5V Relay Module for Arduino Raspberry Pi DSP AVR PIC ARM | $8.98 |
| 2 | 2PCS Two Position Three Way Miniature Solenoid Valve DC 5V 6V | $9.95 |
| 1 | LEDMO Switching Converter, AC/DC Power Supply, AC 100V/240V to DC 12V 10A | $9.95 |
| 1 | Yeeco DC 3.5-12V 6V 9V 12V Water Pump Electric Brushless | $13.46 |
| 1 | Elegoo MEGA 2560 R3 Board ATmega2560 ATMEGA16U2 | $11.99 |
| 1 | OCR 20PCS 2.54mm Breakaway PCB Board 40Pin Male and Female Header | $6.49 |
| 1 | Lasko 106 My Heat Personal Ceramic Heater, Purple | $19.23 |
| 1 | URBEST Inlet Module Plug 5A Fuse Switch Male Power Socket 10A 250V 3 Pin | $5.99 |
| 1 | Sandisk Ultra - Flash memory card - 16 GB | $9.95 |
| 1 | Arducam 15 Pin 1.0mm Pitch to 22 Pin 0.5mm Camera Cable for Raspberry Pi Zero | $7.99 |
| 1 | Remington Industries 22 AWG Gauge Stranded Hook-Up Wire | $10.35 |
| 1 | Heat Shrink Tubing 532pcs innhom Ratio 2:1 | $7.49 |
| 1 | Mini Mist Maker Fogger Water Fountain Pond Fog Machine Atomizer | $10.99 |
| 1 | JSER Left Angled 90 Degree Micro USB OTG to Standard B Type | $6.00 |
| 1 | 18 in. x 24 in. x 0.093 in. Clear Acrylic Sheet Glass Replacement | $10.27 |
| 1 | GE All Purpose Silicone I 10.1 oz. Clear Window and Door Caulk | $5.21 |
| 1 | Abbott Rubber Company 1 in. O.D. x 3/4 in. I.D. x 10 ft. Vinyl Tube | $21.32 |
| 1 | Unique Bargains 13.1Ft Clear White Flexible Air Pump Bubble Oxygen Pipe Tube | $9.38 |
| 1 | Aqueon® Glass Aquarium 10gal | $14.99 |
| 1 | Arducam 1602 16x2 LCD Display Module White on Blue with Backlight | $5.99 |
| 1 | 10Pcs 5 x 7 cm DIY Prototype Paper PCB Universal Board New | $6.99 |
| 1 | PryEU 4-Pack White 12V Super Bright LED Strip Lights Waterproof 12'' 30cm | $12.48 |
| 1 | RoadPro RPCBH-25 Hardwire Replacement CB Power Cord-2 wire , 25-Feet | $5.23 |
| 1 | ClearMax Universal 18AWG Power Cord (UL Approved), 12-Feet | $7.99 |
| 1 | 50CT Peat Strip | $6.00 |
| 1 | Aqua Culture Small Pebbles Aquarium Gravel, 5 lb | $3.98 |
| 1 | Small Enclosed Piezo w/Wires | $4.94 |
| 1 | Pixma USB 2.0 Printer Cable Cord A-B 10' 10 FT | $4.99 |
| 3 | USB Car Charger | $0.75 |
| 1 | Cooler Master Sleeve Bearing 92mm Silent Fan | $5.97 |
| 2 | Cooler Master Rifle Bearing 80mm Silent Cooling Fan | $4.99 |
| 1 | TOOGOO(R) 30mm x 30mm x 10mm 3010S 12V 0.06A Brushless DC Cooling Fan | $2.17 |
| 1 | 1 Gallon Plastic Jar, Wide Mouth, Clear | $10.69 |
| 1 | Crystal Clear Plastic Jars with Screw on Lids 16 oz Set 6 Wide Mouth | $16.95 |
| 1 | Blue Sea Systems 8 Circuit 20A Terminal Block | $5.24 |
| 1 | PCB Mount Screw Terminal Block Connector, 100 Pack (2 Pole 5 mm Pitch, 10A 300V) | $9.95 |
| 1 | Hisurprise 1000 Pcs Black Plastic Cable Zip Tie Fasten Wrap 80mm x 2mm | $3.40 |
| 1 | 6 Gauge Clear Vinyl Fabric By The Yard | $1.95 |
| 1 | Sonline 50x Through Hole Carbon Film Resistors 220 Ohm 1/4W 5% | $1.78 |
| Total (Your price tag may vary based on what you buy.) | $280.07 |
Notes:
- I've been told capacitive moisture sensors are better and last a lot longer than resistive moisture sensors that tend to corrode.
- Looking to use LED Grow Lights.
- Might switch out the heater with hairdryer with a mini P.C cooling fan instead to get rid of noise and for a less aggressive airflow.
- Make sure the mini fountain fogger is 12v.
Daniyal Ansari
