This project is a fully discrete stepper motor driver built from basic electronic components (MOSFETs, resistors, standard logic) rather than using black-box commercial ICs like A4988. The primary goal is educational: to create an open architecture that allows engineering students to visualize phase stepping sequences, probe gate signals with an oscilloscope, and physically understand H-Bridge operation and thermal dissipation under load. Currently in the perfboard prototyping phase.
Components
1×
Arduino Uno
Logic controller used to generate step/dir logic signals and PWM.
4×
IRLZ44N N-Channel Power MOSFET
Main switching elements for the dual H-Bridge configuration
4×
IRF9540 P-Channel Power MOSFET
Discrete Semiconductors / Power Transistors and MOSFETs
The wiring complexity is intentional and functional.
This architecture requires 10 direct control lines from the MCU to drive the individual discrete stages (including the 2N2222 pre-drivers and logic-level low-side gates).
Additionally, 3 feedback lines are routed back to the MCU's ADC to read the voltage drop across the 0.1-ohm shunt resistors, allowing for real-time current sensing and active control.
