Raspberry Pi CM5 TV Stick Lite
A compact CM5 carrier board that plugs directly into HDMI
mbsmbs
0 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
The Raspberry Pi CM5 TV Stick is a carrier that plugs directly to HDMI port. Perfect for Kodi, RetroPie, or just using a Pi attached directly to a monitor or TV for any use case.
Board specs:
Compatible with Raspberry Pi CM5 Lite and eMMC variants
HDMI plug
Micro SD card connector
USB-C connector for data/power
Two USB3.0 USB-A connectors
IR receiver
User button
Power button
RPI_nBOOT button for CM5 eMMC programming
Fan connector
Power and Act LEDs
