REAL-AI-Benchmark: A Practical Benchmark Suite for Real-World AI Reasoning
REAL-AI-Benchmark is a benchmark suite designed to evaluate large language models and multimodal AI systems under conditions that are closer to real technical work than to conventional synthetic leaderboard tasks. The purpose of the project is not merely to ask whether a model can produce fluent text, imitate reasoning, or solve a memorized puzzle. Its purpose is to test whether an AI system can follow a demanding chain of reasoning, preserve numerical and logical consistency, generate executable code, detect edge cases, respect constraints, and make defensible decisions in problems that resemble real engineering, programming, and physical-system analysis.
The name REAL-AI-Benchmark was chosen deliberately. The central idea is that many public AI benchmarks are increasingly detached from the kind of work that engineers, researchers, system designers, and technical decision-makers actually need. A model can rank highly on synthetic evaluations while still failing at practical tasks: producing code that does not compile, skipping a hidden logical condition, making an unjustified decision, confusing an intermediate value with a final result, or giving a confident but physically wrong answer. REAL-AI-Benchmark was created to expose exactly those weaknesses.
The benchmark suite is organized into several GO benchmark families, from GO-1 to GO-6. Each benchmark is constructed as a compact but nontrivial technical task. The problems are intentionally small enough to be reproducible and manually auditable, but dense enough to require disciplined reasoning. They are not designed to reward verbosity, marketing-style explanations, or superficial confidence. They are designed to reward correctness, traceability, reproducibility, and operational competence.
A key methodological principle of this project is that an answer is not evaluated only by its final conclusion. The process matters. A model is expected to show how it derived the result, which assumptions it used, how it handled intermediate states, whether it proved uniqueness or non-uniqueness where required, and whether its code actually implements the same logic described in the explanation. This is important because in real technical work a correct final sentence is not enough. If the chain of reasoning is broken, the result cannot be trusted.
Another important principle is that the benchmark does not treat code as decorative. Several tasks require the model to produce Zig code, not merely pseudocode. This was done intentionally. Zig is strict enough to reveal whether the model understands concrete syntax, type discipline, memory and array handling, and modern compiler constraints. Many models produce plausible-looking programs that fail immediately at compilation. REAL-AI-Benchmark records that failure as meaningful evidence. In real engineering, code that does not compile is not a solution; it is an unfinished claim.
The earlier GO benchmarks focus on symbolic reasoning, discrete structures, state transitions, candidate generation, inverse verification, uniqueness proofs, and executable validation. These tests examine whether a model can transform a formal specification into a correct result and then support that result with a programmatic implementation. The tasks often include deliberate traps: similar candidate paths, near-matching outputs, strict indexing rules, exact Hamming distances, or proof obligations that cannot be satisfied by intuition alone. The aim is to test precision under constraint.
The later benchmark family, especially GO-6, extends the project into a new direction: physical-AI benchmarking. GO-6 was introduced because we wanted the benchmark suite to move beyond purely textual and mathematical tasks. Real technical intelligence does not operate only on clean digital inputs. It often begins with imperfect observations: analog gauges, sensor readings, measurement intervals, noise, uncertainty, and dynamically coupled physical variables. GO-6 therefore combines visual instrument reading, fuzzy logic, dynamic simulation, and final action selection.
In the multimodal GO-6 version, the model is given analog instrument images rather than all sensor values as ready-made digital numbers. It must read temperature, pressure, flow, vibration, and pressure trend from gauge-like images. It must then assign nominal values and reasonable uncertainty intervals. This step is essential: physical measurement is not the same as copying numbers from a JSON object. A model that reports false precision from an analog dial is not demonstrating engineering competence; it is demonstrating a lack of measurement awareness.
After reading the instruments, GO-6 requires fuzzy inference. This reflects the fact that real physical systems are rarely binary. A temperature can be partially normal and partially high. A pressure can be close to a transition zone. A vibration level can be unstable without yet being catastrophic. The model must compute membership values, activate fuzzy rules, aggregate risk, and derive an initial fuzzy decision. However, the test is constructed so that the initial fuzzy decision is not necessarily the correct final action.
This is one of the most important ideas in the benchmark. A high-risk state may suggest an emergency response, but the most aggressive intervention may produce dangerous secondary effects. In GO-6, an emergency action can reduce pressure and temperature while increasing vibration so strongly that the final state becomes catastrophic. Therefore, the model must not stop at the first plausible rule-based conclusion. It must simulate the consequences of each available action over several time steps, classify the resulting states, eliminate catastrophic options, and select the best remaining action according to a defined criterion.
This makes GO-6 a test of causal and dynamic reasoning, not just arithmetic. The model must understand that action selection is not the same as state classification. It must distinguish between “the system is currently dangerous” and “the most aggressive action is optimal.” That distinction is central to real-world engineering decision-making, and many AI systems fail exactly there.
The scoring methodology follows an additive and transparent structure. Each component contributes to the final score: instrument reading, physical consistency, fuzzy inference, dynamic simulation, final decision, proof of uniqueness, code quality, and output formatting. No single subjective impression should dominate the grade. A model that solves the reasoning but fails the code loses code points; a model that writes compilable code but makes the wrong decision loses reasoning points. This prevents arbitrary evaluation and makes results comparable across models.
REAL-AI-Benchmark is intended for practical comparison of frontier cloud models, local models, quantized models, reasoning-tuned systems, multimodal systems, and specialized prompts. It is especially useful for exposing differences that are hidden by standard leaderboards. A model may be eloquent but careless. Another may be slow but reliable. A third may solve the mathematics but fail compilation. A fourth may handle digital inputs but fail when asked to read analog instruments. These distinctions matter in real deployment.
The project also emphasizes reproducibility. Benchmark prompts, reference outputs, result schemas, methodology documents, raw logs, and scoring rubrics are intended to be published together. This allows others to inspect not only the final ranking but also the evidence behind it. The benchmark is not meant to be a secret black-box score; it is meant to be auditable.
In summary, REAL-AI-Benchmark exists because practical AI evaluation must move beyond polished demos and synthetic scores. The real question is not whether a model sounds intelligent, but whether it can reason reliably when precision, constraints, code execution, physical causality, and decision consequences all matter at the same time. This benchmark suite is a step toward measuring that kind of intelligence: not theatrical intelligence, not leader-board intelligence, but operationally useful AI competence.
Jovan
