When LoRa Broke My Project and How ArduLora Fixed
ArduLora: Arduino‑friendly LoRa/LoRaWAN (STM32+RAK3172) for reliable long‑range, low‑power IoT — easy setup, field‑ready, open‑source.
0 followers
I believed LoRa would be the silver bullet for my remote IoT nodes. Instead I hit the same hard limits over and over: packets lost at short distances, 18650 batteries drained in weeks, fragile radio links that dropped without warning, and a stack of expensive “fixes” that only made the system more complex. ArduLora was born from that frustration — a hardware and software package designed to solve the real problems I faced in the field.
The problem — what actually went wrong in the field
  • Advertised range vs. reality — on paper the nodes and gateway “should” talk for kilometers. In practice, packets vanished at a few hundred meters because of antenna placement, local interference, and suboptimal radio profiles.
  • Battery life that lied — a 18650 cell that should last months was empty after weeks. Sleep modes were half‑implemented, wake logic was clumsy, and firmware didn’t manage power cycles reliably.
  • Configuration hell — frequency, spreading factor, bandwidth, power: every change required long test cycles. Logs were sparse, and debugging remote nodes was painful.
  • Rising cost and complexity — to patch each failure I added better antennas, external power modules, and extra sensors. The BOM and maintenance overhead ballooned.
  • Developer experience gap — scattered libraries, inconsistent APIs, and missing examples meant new users spent days just getting a stable send/receive loop.
The turning point and the solution — ArduLora
We stopped patching and started designing for the real world. ArduLora is the result: a reference board and a cohesive library built from the ground up to address those exact pain points.
What ArduLora delivers
  • Field‑ready hardwareArduinoLoRa Rev 1.0 (STM32 + RAK3172) with clear, labeled I/O, screw terminals for robust wiring, and a secure 18650 holder so batteries are easy to swap in the field.
  • Practical radio profiles — preconfigured LoRa/LoRaWAN profiles tuned for real environments, plus guidance for antenna placement and power settings so you stop guessing and start getting packets through.
  • Power management by design — deep sleep modes, wake‑on‑interrupt, and example patterns for duty cycles that actually extend battery life in real deployments.
  • A friendly Arduino API — a single, consistent library with clear examples for P2P and LoRaWAN, built‑in retry/ACK logic, and logging helpers for fast debugging.
  • Real results and a practical flow
After switching to ArduLora in our field tests we saw measurable improvements: higher packet success rates, significantly longer battery life, and far fewer emergency site visits. The development cycle shortened because examples and APIs were consistent and predictable.
Portable Network Graphics (PNG) - 6.53 MB - 05/05/2026 at 18:03
Preview
  • 1 × RAK3172
  • 1 × MAX485 Switches and Multiplexers / Analog Switches and Multiplexers
  • 1 × MC34063 Power Management ICs / Switching Regulators and Controllers
  • 1 × CH340E
  • ArduLora Library v1.0.0 - Initial Release
    namnam2 hours ago 0 comments
    🚀 Initial Release of ArduLora Library (v1.0.0)
    This is the first stable release of the ArduLora library for the RAK3172 module, designed to make LoRa development on Arduino IDE incredibly simple.
    Key Features:
    • 100% compliant with RUI3 v4.2.4+ firmware.
    • Clean and human-readable pin definitions in ArduLora.h (e.g., ARDULORA_LED_STATUSARDULORA_RS485_TX).
    • 24 out-of-the-box compiled examples covering:
      • LoRa P2P: Transmission, Receiving, and settings configurations.
      • LoRaWAN: OTAA, ABP, Class B, Multicast, and network joining.
      • Hardware Interfacing: Modbus RTU (Master/Slave), I2C Sensors (SHT3x, LIS3DH, BH1750), GPS, Analog, and Digital IO.
      • System: Power saving, Multitasking, and Hardware Timers.
View project log
  • 1
    Prerequisites
    Hardware: ArduinoLoRa Rev 1.0 board, 18650 battery, LoRa antenna, USB‑C cable, sensor(s).
    • Software: Arduino IDE or Arduino CLI, STM32 board support (if required), ArduLora library (or your library).
    • Services: LoRaWAN gateway credentials if using OTAA/ABP (AppEUI, DevEUI, AppKey).
  • 2
    Hardware Assembly
    • Insert battery: Place the 18650 cell in the holder with correct polarity and ensure firm contact.
    • Attach antenna: Screw the LoRa antenna onto the SMA connector; keep it clear of metal.
    • Connect sensors: Use screw terminals or headers to wire I2C, UART, or GPIO sensors.
    • Power check: Connect USB and open Serial Monitor at 115200 to confirm the board boots and prints initialization logs.
  • 3
    Wiring Guide
    • I2C: SDA → SDA pin; SCL → SCL pin; 3.3V → VCC; GND → GND.
    • UART: Sensor TX → board RX; sensor RX → board TX; common GND.
    • Power: 18650 supplies Vbat; USB should auto‑switch when connected.
    • Antenna: Keep antenna upright and away from metal enclosures.
View all 5 instructions
namnam wrote an hour ago point
By at
https://www.tindie.com/stores/thanhnamlt5
https://www.elecrow.com/ardulora.html
