Notes from our journey building a real-world SDR platform.
Why We Built Integrive-100: From SDR Experiments to Real Wireless Prototypes
Software-defined radio has fundamentally changed the way wireless systems are researched and developed. With an SDR platform, engineers can generate and receive RF signals, experiment with new waveforms, evaluate modulation schemes, and validate communication algorithms without building custom radio hardware from scratch.
We followed the same path.
We have used commercially available SDR platforms extensively for wireless communication research and algorithm development. They are excellent tools for learning, experimentation, and rapid proof-of-concept development.
But as our work progressed from signal experiments toward complete wireless communication systems, our requirements began to change.
We needed more than an SDR for observing and processing signals.
We needed a platform on which we could actually build a wireless communication prototype.
Figure 1. Integrive-100, the SDR development platform we built during this project.
The Gap Between an SDR Experiment and a Wireless System
A laboratory SDR experiment and a practical wireless communication system may use many of the same signal-processing algorithms, but they are not quite the same engineering problem.
In simulation environments such as MATLAB or Python, researchers can focus primarily on the algorithm itself. Many real-world effects can be simplified, modeled separately, or temporarily excluded.
Once an algorithm moves onto real RF hardware, however, phase noise, carrier frequency offset, I/Q imbalance, fixed-point effects, timing, interfaces, and hardware constraints all become part of the system.
Sometimes the challenge is not the algorithm itself. It is everything around it.
A new synchronization, channel-estimation, or equalization algorithm, for example, may assume a particular frame structure, pilot configuration, or position in the processing chain. If the development platform does not provide sufficient control over those elements, engineers may end up spending more time adapting their algorithms to the platform than evaluating the ideas themselves.
We wanted to reduce that friction.
A real communication prototype requires the entire signal chain to operate together, including RF processing, digital signal processing, synchronization, OFDM, modulation and demodulation, FEC, framing, packet processing, and communication protocols.
But we kept coming back to this question:
Why should we have to redesign the entire PHY just to test a new algorithm?
This frustration became one of the key ideas behind Integrive-100.
How We Structured the PHY
We wanted the PHY processing chain to be accessible enough that developers could focus on the particular function they wanted to investigate without having to build an entire communication system from scratch.
Integrive-100 provides an FPGA-based PHY implementation in the Programmable Logic (PL), together with an ARM-based Processing System (PS) running Linux. During algorithm development, a selected PHY function can be implemented in software on the PS, while the remaining PHY functions continue to execute in the PL.
This creates a practical development model:
Develop the PHY function you want to investigate in the PS. Let the existing PL implementation handle the rest of the communication chain.
What makes this particularly useful is that the algorithm can be evaluated as part of an operating PHY chain rather than only against previously captured data. PHY processing can be handled at the symbol level, allowing developers to observe and evaluate how their algorithms behave while the communication system is running under real RF conditions.
For example, a researcher developing a new equalization algorithm can implement the function in software on the PS while synchronization, OFDM processing, demodulation, and other surrounding PHY functions continue to operate as part of the system. The researcher can therefore evaluate the algorithm within the actual PHY processing flow, including the effects of the RF channel and hardware impairments.
The same approach can be applied to other PHY algorithms. Instead of rebuilding an entire PHY just to evaluate one new idea, developers can concentrate on the function they want to innovate and test it within a working communication system.
Once the algorithms and system architecture have been validated, the complete PHY can be implemented in the PL for deterministic real-time operation, providing a path from algorithm development to a working wireless prototype.
This creates a natural development path:
Figure 2. Integrive-100 development path from software-based algorithm development and symbol-level validation on real RF hardware to FPGA implementation and product prototyping.
From Experimentation to Prototyping
Integrive-100 integrates an RF transceiver, FPGA fabric, an embedded ARM processor running Linux, and a software development environment into a single SDR platform.
Rather than treating the radio simply as a source and sink of RF samples, we designed Integrive-100 as a platform for developing a complete communication PHY.
RF parameters and PHY functions such as modulation, FEC, FFT size, and cyclic prefix can be configured through software, while FPGA-based processing provides the real-time execution needed for a practical wireless communication chain.
This combination makes it possible to move beyond simulation and isolated signal experiments, integrate new algorithms into a working PHY, and evaluate them at the symbol level on real RF hardware. When deterministic real-time performance is required, the complete PHY can ultimately be implemented in the FPGA.
In other words, we wanted to bridge a difficult transition:
from proving that an algorithm works to proving that a wireless system works.
Why Hardware Quality Matters
As an SDR moves from experimentation toward communication prototyping, RF signal quality becomes increasingly important.
High-order modulation such as 256-QAM leaves considerably less room for RF impairments than simpler modulation schemes. Phase noise, I/Q imbalance, image components, and distortion can directly affect communication performance.
For this reason, we designed Integrive-100 with particular attention to RF signal integrity.
In loopback testing, the combined transmit-and-receive EVM of Integrive-100 measured ≤ −35 dB, providing approximately 3 dB of margin relative to the −32 dB EVM requirement for 256-QAM.
We have also characterized phase-noise contribution and image rejection as part of our RF performance evaluation.
These measurements are important because flexibility alone is not enough. A development platform intended for advanced wireless prototyping must also provide the signal quality needed to evaluate the waveform running on it.
What We Wanted to Build
From the beginning, we did not want Integrive-100 to be tied to a particular wireless standard or application.
What we wanted was a platform where we could explore new PHY algorithms and waveforms, turn them into working wireless links, and test them over the air on real RF hardware.
This is the story of why we started the Integrive-100 project, what mattered to us along the way, and how those priorities shaped what we built.
