Hardware Composition
1. Sensor Board: AR0234 image acquisition board
2. Core Board: NXP i.MX8M main control processing core
3. Interface Board: Standard UART external communication board
Key Specifications
· Image Sensor: AR0234 Global Shutter CMOS
· Resolution: 1920×1200 (2.3MP)
· Frame Rate: 120fps at full resolution
· Shutter Type: Global shutter, no motion smear
· Main Controller: NXP i.MX8M
· External Interface: UART serial port
· Operation Feature: Industrial wide temperature range, anti-interference, stable long-term operation on site
Core Features
1. High Performance with Global ShutterNo rolling shutter effect or motion blur in high-speed scenarios. High frame rate and high resolution perfectly meet high-speed detection requirements of production lines.
2. Split Modular StructureThree independent boards support separate replacement, upgrade and maintenance. Flexible for matching different lenses and computing power customization.
3. Powerful Computing & Easy Developmenti.MX8M heterogeneous multi-core architecture, supports Linux system and hardware image acceleration, convenient for secondary algorithm development and edge deployment. Universal Interface & Easy IntegrationStandard UART communication can be directly connected to PLC, industrial controller and embedded host, with simple wiring and fast project implementation.
Johanna Shi
marcaz
Blade Master
Simone
