Today i revised the wifi esp-03 module software .. i opted to use telnet at this stage ..
wrote the code and test on mobile app
all is working !!
A project log for WiFi 3 channel Temperature Switch
The temperature switch takes three readings from three sensors and displays then on oled and also according to the conditions switch relay
all is working !!
