The project was tested on the field with the three sensors connected to a a/c unit
the project behaved as expected.. wifi range varies according to building type .
A project log for WiFi 3 channel Temperature Switch
The temperature switch takes three readings from three sensors and displays then on oled and also according to the conditions switch relay
