BitCards: Learn Electronics Without Coding
A hands-on system that teaches digital logic and electronics using physical cards — no coding, just real understanding.
Public Chat
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
Learning electronics is hard. Not because it's complex — but because it's taught in a way that doesn't feel real.
Most beginners get stuck between theory and code, without ever truly understanding what’s happening.
When I started learning electronics, I faced the same issue. Tutorials showed code, diagrams, and simulations — but I couldn't feel how logic actually works.
Concepts like AND gates, flip-flops, or binary counters remained abstract. So I decided to build something different.
BitCards is a hands-on system that lets you learn digital logic and electronics using physical cards.
Each card represents a real logic function — and when connected, they create actual working circuits.
HOW IT WORKS
Instead of writing code:
• You place cards
• You connect them
• You instantly see the result
From simple logic gates like AND/OR…to more advanced systems like flip-flops and counters.
The goal is simple:
Make electronics intuitive, visual, and accessible.
