https://www.amazon.com/dp/B0FHQK73W1
Eventually settled on the chinese plexi tubes. They were 2.75" inner diameter & 36" long, slightly longer than the longest bat & a bee's dick wider, as expected. There was no way to separate the bats from the sides. Any o-ring around the fat end would slide up & down.
Stuffed the fat ends with paper to keep the bats from sliding up & down. Additional stability might be gained by stuffing paper around the handles.
lion mclionhead
