Project Overview
This project is a smart IoT-based water vending system designed for remote and off-grid communities where access to clean drinking water and stable electrical infrastructure is limited. The system combines embedded automation, RFID authentication, solar-powered operation, and intelligent dispensing control to create a reliable and scalable smart water distribution platform.
The objective of the project was to develop a compact and energy-efficient solution capable of operating autonomously in desert and rural environments while reducing operational complexity and maintenance requirements. The system demonstrates how a custom built vending machine can deliver secure and automated water access using embedded electronics and renewable energy technologies.
The prototype integrates an ESP32 microcontroller, RFID-based user authentication, relay-controlled dispensing, DC power regulation, and solar battery operation inside a compact controller enclosure optimized for field deployment.
Key Features:
  • ESP32-based embedded control system
  • RFID-enabled user authentication
  • Solar-powered off-grid operation
  • Automated water dispensing mechanism
  • Low-power embedded electronics design
  • Relay-controlled pump and valve switching
  • Expandable IoT monitoring capability
  • Compact modular enclosure
  • Smart energy management system
  • Suitable for harsh outdoor environments
System Architecture
The system consists of five major subsystems:
  1. Solar Power Management
  2. ESP32 Embedded Controller
  3. RFID Authentication Module
  4. Water Dispensing Unit
  5. Relay and Protection Circuitry
The solar panel charges the battery system, which powers the complete vending machine. A DC-DC buck converter regulates voltage for the ESP32 controller and peripheral modules.
When a registered RFID card is scanned, the ESP32 validates the authentication request and activates the dispensing cycle through a relay-controlled pump or valve system.
Hardware Components
ESP32 Development Board
The ESP32 acts as the central processing unit of the system and handles:
  • RFID data processing
  • Relay control
  • Dispensing logic
  • User interaction
  • IoT communication support
The ESP32 was selected because of:
  • Built-in WiFi and Bluetooth
  • Low power consumption
  • Reliable GPIO support
  • Easy cloud integration
  • High flexibility for embedded applications
The RFID module is used for secure user identification and controlled water access.
Functions include:
  • RFID card detection
  • User authentication
  • Access authorization
  • Dispensing trigger activation
The authentication mechanism helps prevent unauthorized water usage and enables future prepaid or smart card integration.
Relay Module
The relay module isolates the high-current pump circuitry from the low-voltage controller electronics.
Used for:
  • Pump switching
  • Solenoid valve control
  • Electrical load isolation
This improves both safety and system reliability.
Solar Power System
The vending machine is powered using:
  • Solar panel
  • Rechargeable battery
  • Charge controller
  • DC power regulation system
The solar-powered architecture allows fully autonomous operation in off-grid desert locations.
Water Dispensing System
The dispensing mechanism can operate:
  • DC water pumps
  • Solenoid valves
  • Timed water flow systems
The design supports future integration with:
  • Flow sensors
  • Water quantity monitoring
  • Smart metering systems
Embedded Controller Enclosure
The electronics were assembled inside a compact modular enclosure containing:
  • ESP32 controller
  • RFID module
  • Relay board
  • Buck converter
  • Terminal connectors
  • Protection circuitry
The enclosure was designed for:
  • Easy servicing
  • Organized wiring
  • Field maintenance
  • Dust protection
  • Compact installation
Special consideration was given to maintaining serviceability for remote deployment conditions.
Working Principle
Step 1 —...
