This log will be amended as I fill in details that I may have missed.
Your OS may have Rust available in their package repositories. But due to the rapid pace of development it's best to install a Rust toolchain outside of the package system. Rust developers have streamlined this task.
You need two important programs: rustup which is a toolchain installer (and maintainer), and cargo, installed by rustup, which is a project manager. The other programs like rustc, the compiler, will be installed by rustup.
Before you install rustup, you need to decide if you accept the standard location for the software, in the case of Linux, under your home directory in ~/.cargo, as explained here. If like me, you dislike lots of package files under home (unfortunately this is the norm these days with Arduino, PlatformIO, etc. etc.), you can change the directories. There are two environment variables, and I've set them thus:
export RUSTUP_HOME=/usr/local/lib/rustup CARGO_HOME=/usr/local/lib/cargo
If you choose to change them, edif your ~/.bash_profile to export these environment variables. Also put this command in ~/.bash_profile after so that the correct executables are found.
. "$CARGO_HOME/env"
Logout and login again if necessary to ensure that these settings are in place before you install rustup following the instructions at the website.
The help text for rustup indicates what it does:
$ rustup --help
rustup 1.29.0 (28d1352db 2026-03-05)
The Rust toolchain installer
Usage: rustup[EXE] [OPTIONS] [+toolchain] [COMMAND]
Commands:
install Install or update the given toolchains, or by default the active toolchain
uninstall Uninstall the given toolchains
toolchain Install, uninstall, or list toolchains
default Set the default toolchain
show Show the active and installed toolchains or profiles
update Update Rust toolchains and rustup
check Check for updates to Rust toolchains and rustup
target Modify a toolchain's supported targets
component Modify a toolchain's installed components
override Modify toolchain overrides for directories
run Run a command with an environment configured for a given toolchain
which Display which binary will be run for a given command
doc Open the documentation for the current toolchain
man View the man page for a given command
self Modify the rustup installation
set Alter rustup settings
completions Generate tab-completion scripts for your shell
help Print this message or the help of the given subcommand(s)
Arguments:
[+toolchain] Release channel (e.g. +stable) or custom toolchain to set override
Options:
-v, --verbose Set log level to 'DEBUG' if 'RUSTUP_LOG' is unset
-q, --quiet Disable progress output, set log level to 'WARN' if 'RUSTUP_LOG' is unset
-h, --help Print help
-V, --version Print version
Discussion:
Rustup installs The Rust Programming Language from the official
release channels, enabling you to easily switch between stable,
beta, and nightly compilers and keep them updated. It makes
cross-compiling simpler with binary builds of the standard library
for common platforms.
If you are new to Rust consider running `rustup doc --book` to
learn Rust.
Common commands:
$ rustup update
Install the current stable release of Rust for your host platform
$ rustup toolchain install stable
Toolchain means a release channel, e.g. default, nightly. If you are thinking about MCU targets, then the term is target.
Here's a relevant fact: gcc requires a different toolchain for each MCU family. That's why the toolchain for the classic Arduino starts with avr-, that for the STM32 starts with arm-, and for the WCH32V series riscv-. LLVM however uses the same compiler for all targets, and you can install a new target without installing another compiler. Here are the targets I have installed:
$ rustup target list | grep installed
riscv32i-unknown-none-elf (installed)
thumbv6m-none-eabi (installed)
x86_64-unknown-linux-gnu (installed)
Riscv32i is for the WCH32V MCUs, thumbv6m is for the RP2040, and x86_64 is for my Linux workhorse.
Now we come to cargo. This is a project manager which allows you to manage all aspects of a project, initialising the project directory structure, installing dependencies, building binaries, running them, debugging them, installing them, and so forth. It's modelled after the successful Ruby on Rails tool rails which triggered similar programs for other development environments, like gradle for Groovy (java). Here is the help text for cargo which gives you an idea of what it does:
$ cargo --help
Rust's package manager
Usage: cargo [+toolchain] [OPTIONS] [COMMAND]
cargo [+toolchain] [OPTIONS] -Zscript <MANIFEST_RS> [ARGS]...
Options:
-V, --version Print version info and exit
--list List installed commands
--explain <CODE> Provide a detailed explanation of a rustc error message
-v, --verbose... Use verbose output (-vv very verbose/build.rs output)
-q, --quiet Do not print cargo log messages
--color <WHEN> Coloring [possible values: auto, always, never]
-C <DIRECTORY> Change to DIRECTORY before doing anything (nightly-only)
--locked Assert that `Cargo.lock` will remain unchanged
--offline Run without accessing the network
--frozen Equivalent to specifying both --locked and --offline
--config <KEY=VALUE|PATH> Override a configuration value
-Z <FLAG> Unstable (nightly-only) flags to Cargo, see 'cargo -Z help' for details
Commands:
build, b Compile the current package
check, c Analyze the current package and report errors, but don't build object files
clean Remove the target directory
doc, d Build this package's and its dependencies' documentation
new Create a new cargo package
init Create a new cargo package in an existing directory
add Add dependencies to a manifest file
remove Remove dependencies from a manifest file
run, r Run a binary or example of the local package
test, t Run the tests
bench Run the benchmarks
update Update dependencies listed in Cargo.lock
search Search registry for crates
publish Package and upload this package to the registry
install Install a Rust binary
uninstall Uninstall a Rust binary
... See all commands with --list
See 'cargo help <command>' for more information on a specific command.
If you're thinking what does package have to do with my project, your project is a package too, and cargo is how you manage it. Crate is the Rust term for a standard package.
Fun fact: Look at the executables in $CARGO_HOME/bin. You'll see that a lot of them are just links to rustup, including cargo and rustc. Rustup is a chameleon program, playing different roles depending on how it's invoked.
When I did the initial install of the Rust toolchain, I was beset by one problem: I couldn't compile probe-rs-tools which comprise probe-rs, cargo-flash, and cargo-embed. The compile failed with not finding udev functions. An overview of the three tools is here and their functions explained here. So I installed them from a binary pacakge. I finally got around to figuring out why. Long story short, I needed the libudev-devel package which contains the details of the interface to the OS userland device handling. In other distros it could be called libudev-dev. But the catch was that in my distro, they have been merged into systemd-devel. After installing this RPM package, the compilation succeeded.
Installing additional tools
Now that we have the compiler, let's install some useful tools. A useful one is llvm-tools. We get this by:
$ rustup component add llvm-tools
With this we get the usual complement of binutils tools for Rust LLVM such as rust-size, rust-nm, rust-objcopy, rust-objdump and so forth.
Next we install the crate cargo-binutils, which contain proxy tools for the llvm-tools. By proxy this means it supplies additional information to invoke the base llvm tool. For example when run in the project directory it supplies the target argument for the MCU you are building for.
$ cargo install cargo-binutils
(To be continued)
Ken Yap
