Introduction
An autonomous robotics project built using Raspberry Pi, IR line sensors, and differential motor control for accurate path navigation and real-time movement correction. Inspired by practical embedded robotics systems and educational autonomous vehicle concepts seen across the maker community.
Description
A Raspberry Pi–powered line following robot designed for autonomous navigation on predefined tracks. The robot continuously reads data from infrared sensors placed underneath the chassis and dynamically adjusts wheel movement to stay aligned with the path.
The control system is built around Raspberry Pi GPIO processing with Python-based motor control logic. Sensor feedback is analyzed in real time, allowing the robot to make instant steering corrections while handling sharp turns and curved paths smoothly.
The primary objective of this build was to create a scalable robotics platform that can later be expanded with:
- PID-based motion correction
- Computer vision modules
- Obstacle avoidance
- Wireless telemetry
- AI-assisted navigation
The robot uses a lightweight 4-wheel drive chassis combined with a motor driver module and IR tracking sensors. PWM motor speed adjustment helps maintain stability during movement and improves line tracking precision.
Features
- Raspberry Pi based autonomous navigation
- Real-time IR sensor processing
- Differential motor speed control
- PWM-based steering correction
- Compact low-cost robotics platform
- Expandable architecture for AI and computer vision
- Educational embedded systems project
Hardware Used
- Raspberry Pi
- IR Line Tracking Sensors
- DC Geared Motors
- Motor Driver Module
- Battery Pack
- Robot Chassis
- Jumper Wiring
Software Stack
- Python
- Raspberry Pi GPIO Libraries
- PWM Motor Control Logic
- Embedded Robotics Algorithms
How It Works
The IR sensors continuously detect contrast differences between the black track and the surrounding surface. A raspberry pi f robot follow the track of direction line by line .
Based on sensor feedback, the Raspberry Pi decides whether the robot should move forward, turn left, or turn right.
When the robot drifts away from the line, motor speed is adjusted dynamically to bring it back onto the track. This closed-loop correction mechanism enables stable autonomous movement even on curved paths.
Future Improvements
- PID control tuning
- OpenCV camera integration
- Maze solving algorithms
- WiFi/Bluetooth remote monitoring
- SLAM experimentation
- ROS integration
Why This Project Matters
Line following robots are one of the foundational projects in embedded robotics because they combine electronics, programming, sensing, and real-time decision making into a single practical system. Modern robotics learning platforms often begin with autonomous navigation projects like this before moving toward AI and advanced mobility systems.
This project also demonstrates practical embedded product development skills relevant to industrial automation, warehouse robotics, and autonomous mobility research.
If you're looking to build robotics systems, automation products, or embedded Linux solutions, you can also hire raspberry pi developer services for custom robotics and IoT development.
Himanshu Dada
Víctor Mayoral Vilches
Daniel James Evans
Tommy
alisa.wu
