The Linux heart of the rock is the VoCore module. The version of Linux that the module was made to run is OpenWRT, and now the VoCore is an officially supported platform! https://dev.openwrt.org/changeset/41939
So if you want to build an image, you can just select the VoCore profile when following the instructions here.
