From previous experience, NOT using a NANO, but trying to use an Arduino Mega now.
Some also suggested teensy, but those are a bit expensive.
An Arduino Mega based portable device, having portable power, a display and circuitry to measure voltage, current, pulses, test components (Resistors, Capacitors, Transistors and more) and also be able to serve as a Serial Terminal and MORE.
Planned Features
Handheld form factor
Arduino based
Input Push Buttons
Nokia Graphics LCD
Voltage Input - 0 to 50V or possibly
Current Input - 0 to 5A
Serial Terminal
Sqaure Wave Generator
Pulse Counter
Component Tester - a variant of the SemiConductor Tester
Battery Powered - Chargeable via USB
Serial Connection with PC
People, please give me some so I can actually start ordering the parts for the project.
My plan is,
define the features, compartmentalize the features, test each out individually, given parts availability, finalize schematics, design PCB, get PCB fabricated and $$$$$$
