Hackaday.io Hackaday.io
Sign up Log in
YUMO GLOBE - Digital Clock
A hand-bent 1.5mm brass wire clock sculpture powered by ESP32-C3 with NTP time sync, hardware-multiplexed 7-segment display, and 5-stage SK
yumobuildsYUMO.BUILDS
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
0 comments
4 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
View Gallery
473
0
4
3
Team (1)
  • yumobuildsYUMO.BUILDS
Join this project's team
  • YUMO-GLOBE
  • YUMO- GLOBE
completed project
hardware
ESP32 ESP32-C3 7-SEGMENT clock ntp Fastled SK6812 Neopixel wifimanager arduino platformio brass Wire Sculpture handmade Desk clock led iot open source Maker diy brass wire sculpture
This project was created on 06/04/2026 and last updated an hour ago.
Description
YUMO CLOCK is the fourth build from YUMO BUILDS — a fully working desk clock built entirely from hand-bent 1mm brass rods on a hand-turned wooden base. No 3D printing, no CNC, no moulds. Every angle bent by hand.
— build your own.
Full source code on GitHub:
github.com/yumobuilds/YUMO-GLOBE
Watch the build:
https://www.youtube.com/watch?v=EUGc3DatJw4
An ESP32-C3 Super Mini drives a 4-digit 7-segment display (LTD-4608E) via hardware-multiplexed ISR at 333Hz — zero flicker, even while WiFi and LED tasks run in parallel. Five SK6812 LEDs inside the frame: four ring the base, one at the top.
WiFiManager captive portal on first boot — no hardcoded credentials. Timezone auto-detected via IP geolocation. Syncs every hour with pool.ntp.org and time.google.com.
Five-stage startup LED sequence synced to the display: warm spinner, cool fill, countdown rainbow, neon burst, white strobe finale. Top LED solos after — breathing neon colours, triple-flashing every 30s, full neon show every h
Details
Log In/Sign up to comment
Sign up with Github
OR
A 3D floating display based on Aerial Imaging by Retro-Reflection (AIRR)
Project Owner Contributor
Floating Display Clock
moritz-v-siversMoritz v. Sivers
2021 Hackaday Prize
Sunrise alarm clock
Mountain Clock
zach-archerZach Archer
A wifi controlled infinity mirror that can also display time.
Infinity Clock
sean-wagonerSean Wagoner
It rotates a single LED strip very fast and gives the illusion that the display is made of continuous beams of light
Persistence of vision display [Chronolucciologgio]
bruno-laurencichBruno Laurencich
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "YUMO GLOBE - Digital Clock", please tell us the reason.
Send message
Remove Member
