A standard paper business card feels like a missed opportunity when you can build cool hardware instead.
My goal for this project was to pack an ESP32, microphone, and 40-pixel LED matrix onto a PCB the size of a business card with ability to display an audio visualizer.
This project was made possible by NextPCB, who fabricated and assembled the boards.
They offer great promotions for prototyping and assembly.
Check out their services for your next project: https://www.nextpcb.com/?code=GopnikEnterprises
The hardware is simple.
The board is powered via USB-C, which is regulated to 3.3V for the ESP32.
I routed the LED matrix in a snake pattern to keep the layout as clean as possible.
One difficulty that I wasn't expecting was finding a suitable microphone.
When I was designing the board a month or so ago, many of the common I2S microphones were not available.
I ended up going with the MSM261DGT003, which is a digital PDM microphone.
The WS2812C-2020-V1 LEDs require a 5V logic level, so added an SN74AHCT125DR to shift the 3.3V control signal from the ESP32 to 5V.
The back side of the board has 2 QR codes, one to my LinkedIn and the other to my portfolio site.
It also has my social media info.
The ESP32 handles real-time audio sampling and hosting a local web server for control.
There are 2 main audio visualizer modes:
- A scrolling waveform that calculates the RMS voltage of the audio blocks to display volume.
- A spectrum analyzer that runs a 256-sample Fast Fourier Transform to split the audio into 8 frequency bands that are mapped to the 8 x 5 LED matrix.
The firmware hosts an asynchronous web server and sets up the ESP32 as a standalone Wi-Fi Access Point.
When you connect to the card's network on a phone, you can access the control panel.
From there, you can swap between the audio modes, an ambient breathe effect, a solid color picker, and custom scrolling text.
NextPCB did an amazing job on this board.
The whole process was smooth and the matte black soldermask looks really good.
If you're designing PCBs and want a manufacturing service that handles everything from prototypes to fully assembled boards at an affordable price, check out the link below:
Alex
