1. Project Overview
The APL80501K is a high-performance, compact 1000W programmable electronic load designed for serious bench work. While conventional high-power loads are typically large, heavy and expensive, the APL80501K achieves an compact, lightweight footprint by leveraging a unique thermal path and architectural approach. It trades pure, ripple-free DC loading for a lightweight design, making it ideal for high-power testing where cost and bench space matter most.
Despite its small size, it offers high-end test accuracy with 20-bit voltage and current measurements. Safety is at the core of the design, featuring multiple hardware and software-level automatic shutdowns. For higher currents and power, the system scales seamlessly; multiple units can be daisy-chained and controlled via a unified Web App (Android/Windows) to act as a single high-power load.
You can find a short video demonstrating it in operation here:
2. The Problem & Motivation: A Better Thermal Path
Typical electronic loads rely on large aluminium heatsinks to move energy from a transistor into the air. This "Transistor-to-Heatsink-to-Air" path is bulky, heavy, and relies on expensive components to prevent silicon failure.
The APL80501K takes a different approach by burning energy directly in Nichrome wire. Shifting the thermal load to the resistors themselves simplifies the thermal path, eliminating heavy transistors and heatsinks, and reducing the cost and weight of the unit without sacrificing raw power handling capability.
3. Key Specifications
4. System Architecture
The digital and power sections are galvanically isolated (200V functional) to protect the 12V supply and allow connection of multiple units.
5. Thermal Management & Aerodynamics
The load utilizes 4 x 0.8Ω resistors, each constructed from 7 parallel coils of 0.2mm diameter Nichrome wire (1.4m of wire per resistor). Even at 250W per resistor, the resistive coils stay well below "red glow" temperatures thanks to the large surface area and high-velocity airflow.
The resistors sit inside a 60mm x 60mm channel fed by a speed-controllable fan. A custom air-straightening nozzle equalizes pressure across the channel, ensuring no thermal hotspots. This design results in an exhaust air temperature rise of less than 50°C even when dissipating a full kilowatt.
6. Software & Web Interface
The Web App provides a real-time dashboard with data updates every 10ms, featuring a 10-second rolling V&I plot alongside a command and error log window.
7. Current Status & Roadmap
The existing prototype is performing flawlessly through characterization testing. The final design revision is underway to migrate the 12V input to a standardized USB-C PD connector for easier laboratory integration.
Next Steps: Full verification testing and long-term soak tests.  Add ability to update eSW from the web app over Bluetooth.
I am actively seeking community feedback—are there specific features, test modes or safety edge-cases you’d like to see implemented in the final design?
